Scribus 1.5.0 released
Auf der Scribus-Mailingliste wurde die Veröffentlichung der Developer-Version 1.5.0 von Scribus bekannt gegeben. Hier ist der Originaltext:
Mailingliste - Christopf Schäfer hat geschrieben:After many years of work and more than a thousand bugfixes and feature
implementations, the Scribus Team is pleased to announce the release of
Scribus 1.5.0. Scribus 1.5.0 is a preview of the next stable version 1.6.0
and has primarily been released for testing purposes, so more users can
help us with identifying and fixing bugs. It is not stable enough for use
in real production scenarios yet, but it can help users to become familiar
with the new interface and the amount of new features, the number of which
has almost doubled in comparison to the stable 1.4.x series.
==Most Important Technical Changes==
- Scribus 1.5.0 uses Qt 5 as its UI toolkit. The minimum version to
compile Scribus from source is Qt 5.4.
- The file format has undergone significant changes and may change even
further before the release of 1.6.0. Thus, files created or edited in 1.5.0
cannot be opened in earlier versions of Scribus. Potential changes to the
file format on the road to 1.6.0 notwithstanding, the Scribus Team will
work very hard to make sure that files created by 1.5.0 and the following
technology previews can be opened reliably in the next stable release.
- Unfortunately we cannot offer GraphicsMagick and Open Scene Graph
support for all platforms yet, whereas on Linux (and probably *BSD), GM and
and OSG have become new dependencies.
- Scribus will detect an installed version of UniConvertor and use it to
import some of the vector formats supported by this program into Scribus.
==Most Important New Features==
===General===
-The user interface has been overhauled and restructured in many places.
For example, the context menu takes a lot less screen estate than before,
and the Document Setup / Preferences dialog has been rewritten from
scratch. The Scribus Team is aware of the remaining deficiencies and will
work on resolving these issues before the release of 1.6.0. In some cases
inconsistencies in the UI (e.g. the "Drop Shadow" tab in the Properties
Palette) have been deliberately left in place to receive feedback from
users as to which way they prefer.
- Scribus can now store bitmap images within its native file format.
Previously it was only possible to link to external images.
- Scribus 1.5.0 now offers a "Symbol" or clone feature similar to Adobe
Illustrator: If one master object (Symbol) has been modified, all of its
copies (clones) are being modified as well.
- With the new "Weld" feature, objects can be combined and moved without
being "grouped", i.e., each object remains fully editable.
===Text / Typography===
Scribus 1.5.0 provides some of the most often requested text features,
among them:
- vertical scaling of text;
- orphans and widows control;
- foot and end notes;
- text variables;
- cross references.
Moreover, Inline Objects in text frames are finally fully editable.
===Tables==
In previous Scribus versions tables were nothing more than combined text
frames. Scribus 1.5.0 finally introduces "real" tables that resemble table
features in word processors and other DTP programs, including table styles.
===Graphics===
- A new feature-rich plug-in called 'Picture Browser' enables asset
management for graphics files by tagging them or creating graphics
collections. Graphics files can be dragged into a Scribus document from the
Picture Browser.
- Scribus 1.5.0 supports all advanced gradient types available in Adobe
Illustrator and XARA Designer, including mesh gradients.
- One of the most-requested features -- drop shadows -- is finally
available, albeit still experimental.
- For documents that comprise many large (in terms of file size) bitmap
images, a configurable image cache has been added. It can buffer image
files to the hard drive and free RAM, so Scribus can continue to run
smoothly.
===File Import / Export===
Scribus 1.5.0 is being shipped with a huge number of new or rewritten
import filters, although not all of them are of equal quality, and some are
still experimental.
====DTP Files====
For the first time in its history, Scribus 1.5.0 can open / import files
created by other DTP programs, namely: Adobe InDesign XML (IDML), Adobe
InDesign Snippets (IDMS), Adobe PageMaker (P65, PMD), Apple iWorks PAGES,
Microsoft Publisher (PUB), QuarkXPress Tags (XTG), VIVA Designer XML, and
Xara Page & Layout Designer (XAR).
Regarding DTP formats not yet supported, a workaround is sometimes to use
an output format as an option. Accordingly, Scribus 1.5.0's PDF importer
has been rewritten from scratch, and Scribus can now reliably open almost
every PDF file directly with the original layout intact. For Windows users,
Scribus 1.5.0 also comes with reliable import filters for Microsoft's PDF
alternatives XPS (Windows Vista and 7) and OXPS (Windows 8 and later).
====Vector Drawings====
- The import filter for Adobe Illustrator files has been rewritten from
scratch and Scribus's graphics capabilities have been expanded accordingly,
so most AI files can be imported or opened flawlessly. Moreover, Scribus
can now detect hybrid AI files and enables users to choose between the AI
and the PDF version.
- The import filter for OpenDocument graphics files has been rewritten
from scratch and expanded, so Scribus can now open and import ODG drawings
and ODP slide shows without issue.
- "Layers" in SVG files are now supported if an SVG document is being
opened (as opposed to being imported into an existing document).
- Thanks to the libraries provided by the Document Liberation Project,
Scribus can now import native MS Visio and CorelDraw files.
- Other new import filters: Computer Graphics Metafile (CGM), Photoshop
Custom Shapes (CSH), Micrografx Draw (DRW), Enhanced Metafile (EMF),
StarView Metafile (SVM), WordPerfect Graphics (WPG), Xara Designer (XAR).
====Bitmap Files===
- Scribus 1.5.0 supports the open standard Open Raster (ORA) for complex
bitmap files, including advanced features like layer effects or paths.
- With GraphicsMagick installed, Scribus can import all bitmap files
supported by this program, including GIMP's native XCF format.
- Scribus 1.5.0 can import PGF bitmaps, an open alternative to JPEG 2000.
====3D====
With OpenSceneGraph installed, Scribus 1.5.0 can import 3D objects in all
formats supported by OSG into a new frame type called "3D Annotation".
Scribus also offers limited editing functions, such as setting the lighting
source or the default display mode for a PDF-3D-capable PDF viewer.
====Colors and Fills====
Scribus 1.5.0 can use color palettes in the Adobe Color Swatch (ACO) and
AutoCAD ColorBook (ACB) formats, as well as GIMP Gradients (GGR) and GIMP
Patterns (PAT). The former color manager has been extended to a "colors and
fills manager" to reflect Scribus's new capabilities.
===Output===
The most important new feature with respect to output is the support of
PDF/X-4 in the PDF exporter. Another important addition, at least in some
environments, is an exporter for Microsoft's XPS format.
For a cursory overview of all new features, see:
http://wiki.scribus.net/canvas/Scribus_1.5_Readme
A data sheet is available here:
http://wiki.scribus.net/canvas/File:Dat ... bus150.pdf (English)
http://wiki.scribus.net/canvas/File:Dat ... bus150.pdf (Deutsch)
The complete changelog is available here:
http://bugs.scribus.net/changelog_page. ... sion_id=60
==New Website==
Thanks to Carsten Liersch and Dennis Groenewegen van der Weijden, we're
also pleased to present Scribus via a new and modern website to the world.
==Primary Download Locations==
- Installation packages for Windows, Mac OS X and the source code are
available here:
http://sourceforge.net/projects/scribus ... vel/1.5.0/
- Fedora and CentOS RPMs:
http://download.opensuse.org/repositories/home:/mrdocs
- OpenSUSE, SLED, and SLES RPMs:
- Packaging for *BSD, Solaris and OpenIndiana is beyond our influence. We
recommend updating the respective repository data on a regular basis.
==Download Verification==
Description File Name Sha1sum
Source scribus-1.5.0.7z
7a8dbe7ae7790ecc194dbe9c6c23726bb3b226d7
Source scribus-1.5.0.tar.xz
fdf451037073ee648f135669535508813d61ee7e
OS X Mavericks or higher (DMG) scribus-1.5.0.dmg
55a1e0800b73f7b7b0b136b3ebc1eb6a03ef0b07
Windows 32/64 Bit scribus-1.5.0-windows.exe
9a0ce39350e77d6a907f8aae2b6d803ba6345ef7
Windows 64 Bit scribus-1.5.0-windows-x64.exe
42d489fe1098797772a14113ca2ac49244a4dbd2
==Credits==
The Scribus Team would like to thank Anduin.net and Modirum for their
continued hosting of all of the Scribus websites.
We are grateful to the Organisation Internationale de la Francophonie and
Linux New Media (Germany) for sponsoring.
Special thanks go to Carsten Liersch/Bauwerk Design (Germany) and Dennis
Groenewegen van der Weijden for the design of the new Scribus website.
The Scribus Team is also honored to have Resene Colours (New Zealand), dtp
studio oldenburg (Germany), GiveLife Color System (Spain), Scientific
Illustration Services Corp. (USA), the Newspaper Association of America
(USA) and Software Consulting Services (USA) as Special Supporters and
donors of color palettes and other content since the 1.4.x release, just
like we are grateful to the owner of Vector Portal for the permission to
distribute some of his work as Scribus Templates.
Porting Scribus to OS/2 and eComStation is being supported by Mensys BV
(The Netherlands) and Serenity Systems (USA).
Finally, the Scribus Team would like to thank the many end users,
translators, testers and contributors who helped us with this release.
Re: Scribus 1.5.0 released
Was, Anke, möchtest Du gerne übersetzt haben? Oder gar alles? Noch ist das keine Zusage, nur mal eine Abklärung.
Hallo Arran
ja, wenn schon ... denn schon alles übersetzen ;)
ich denke es ist wichtig, dass auch die deutschsprachigen Mitglieder, die des Englischen nicht so mächtig sind wissen, was es mit der 1.5.0 auf sich hat, sonst hagelt es wieder Beschwerden und das Scribus nicht zu gebrauchen ist, weil es immer abstürzt ... Naja, du kennst das ja ;)
Grüßle
ich wurde eher eine (kurze) mitteilung darüber schreiben...
die release notes für eine (so instabile) entwicklungsversion zu übersetzen, macht mmn weniger sinn.
das ganze release-verfahren war bereits pompös genung! :-)
OK, dann gebt mir drei Tage Zeit. Ich schliesse mich Alessandros Ansicht an. Alles ist sicher zu viel. Wir haben ja keine Lesegemeinschaft mehr, eher eine Bildlianschau-Gesellschaft …
aber dann bitte mit Bildlies :mrgreen:
Ich habe den Text jetzt einmal soweit übersetzt, und ein wenig abgerundet. Ein paar Feature, die in der Readme standen habe ich noch beigefügt. Leider stand auch dort nichts von Ebenen in Musterseiten.
In den nächsten Tagen werde ich noch ein paar Screenshots einfügen um das Ganze ein wenig abzurunden.
vielen Dank für das Übersetzen der Release-Notes! Viele Interessierte, die besonders durch die fehlenden englischen DTP-Fachwörter Schwierigkeiten beim Lesen der originalen Release-Notes haben, können sich so über die Entwicklung von Scribus informieren.
Ich habe eine Anmerkung zum Einbetten von Bildern: Die Funktion war schon vorher in Scribus enthalten (ab 1.4?), nur konnte man Bilder nur unter ganz bestimmten Bedingungen einbetten (z.B. wenn man PICT-Dateien (steinzeitliches Vektor- und Bitmap-Format des Apple-Macintoshs) in Scribus als Vektorgrafik lud). Eine Oberfläche für diese Funktion gab es also nicht.
In Bezug auf:
Bitte alle Fehler, die beim Testen auffallen auf Bugzilla melden --> http://bugs.scribus.net/
ist zu sagen, dass die Scribus-Entwickler nicht Bugzilla, sondern MantisBT als Bugtracking-System einsetzt.
So, Erbsenzählerrei (vorerst ;-) ) beendet :-)
Anke hat geschrieben:Ich habe den Text jetzt einmal soweit übersetzt, und ein wenig abgerundet. Ein paar Feature, die in der Readme standen habe ich noch beigefügt. Leider stand auch dort nichts von Ebenen in Musterseiten.
:einig: :pluseins:
Julius hat geschrieben:...
Ich bin nicht besonders firm mit Übersetzungen. Deshalb bin ich dir sehr dankbar für dein Feedback. Das Einbetten von Bildern bezieht sich doch auf Pixelgrafiken, wenn ich das richtig verstanden habe. Bitte korrigiere mich, wenn ich da etwa falsch verstanden habe. Wenn, dann wir schon etwas schreiben, sollte es schon richtig sein.
In Bezug auf:
Ich habe die Adresse von a.l.e. genommen, die er mir hier im Forum genannt hat. Wenn der nicht richtig ist, bitte ich dich mir den richtigen Link zu geben.
Bei den Bugtrackern ist das auch wieder so eine Sache, wer des Englischen nicht mächtig ist, kann theoretisch nichts tun :( außer Englisch lernen ;)
Grüßle
